Getting a swing arm back in frame
MB
Coast to Coast
Tips from the experienced.... Can't seem to get the angle an pressure right. Seems damn near impossible. I'm sure there's a time honored trick here (CL 450)
Ok, I think I figured out why the fit was a no go. Factory bushings are just a sleeve inside the arm. They rest on a washer inside the "caps" at either end of the swing arm. The new bronze bushings I have have an edge on the outside of a similar width....which I guess fulfills the purpose of the washer. No way it was gonna fit with the lip on the new bushings AND the washer. Am I right?
Sounds likely - if the bronze bushings + caps are a solid fit with zero play in the frame, then that's good.
Oh, and simply measuring / comparing the thickness of the washers vs the flange on the bushings would likely confirm this.
Yes, my CL450 was the same way. I put the cupped washers over the bronze bushings and it fit perfect.
