Great BMW Cafe
CanadaDan
1977 BMW R75/7 'Mojo'
This is CraigC's ride from the www.boxerworks.com forum... great stuff!
Check out the rear-sets... fabulous in their simplicity!
That's a 140 rear tire.
Well it's a small world...
Craig won Best Vintage German at the Chicago Mods vs Rockers III with that bike!
Check out his site at www.cafeboxer.com
Some WILD stuff... Tintin might even start chopping his beloved stock /6 :o
Actually, the bike I won with is this one:
Great forum! Will be stopping by regularly.
Didn't realise just how cool the /5 bucket looks with the tree all decluttered... you build KILLER boxers Chris!
Welcome to the board BTW.
Hmmm... wonder if I could work that bucket with Mojo's speedo (not that it works lol) ;D
Craig... hope your still lurkin around...
How did you manage to get a 140 tire onto the first one pictured? Thats 1.25" bigger than stock and there isn't THAT much width to play with back there... swing arm mod?
No swing arm mod. The rims are drilled so that appropriate offset can be achieved to run a wide tire. The best is Buchanan spoke: http://www.buchananspokes.com/rims.htm They know what they are doing. They will sell you the dilled rim and appropriate spokes if you have the means to assemble and true the wheel yourself.
On my bike, with the 140, the final drive side has 1mm, maybe less clearance between the tire and swingarm. On the other side, 5/8".
The wider tires become important as you increase the engine power. The 70 hp BMWs are arguabley 'under tired' with the 4.00x18 rear tire.
A person I know that did a lot research in this area contends that the best wheel/tire combo for these bikes is an 18"x2.5" front rim with a 100/90 tire and a 18"x3" rear with a 130/80 tire.
The widest tire that should be able to fit is a 150, though this would be tight. I have seen one race bike running a 150 rear. Here is a picture of a 4.25" Sun rim drilled by Buchanan needed to run that 150:
This is my friend Paul's bike that he used to run in BoTT in the 80s. He spent crazy money having a Lester widened so that he could run a 140 rear:
I believe on a 3" or smaller rim, Buchanan changes the angle that the holes are drilled rather than shifting the holes off center like on the 4.25" rim above or Paul's Lester where more material was added to the left side of the wheel.
A steering damper becomes more necessary with the wide rear rim. The stock BMW damper is adequate.
That is a killer bike which looks SO much better in person.
Thanks for making it out to MVRIII with that beauty...
