ello Guys!
My name is Aris and i am from Mykonos, Greece,
Currently i am building a GS 750 into a cafe racer. I need your help as i am trying to change the left original switch to a aftermarket and i am completely new with the wiring.
The cables that are going to the the left switch from the main harness as you can see in the photo are:
ORANGE: Power from ignition switch
WHITE: Lighting switch to dimmer switch
YELLOW: HIGH BEAM
GREY: ILLUMINATION LIGHT
BLACK: Left hand turn signal
LIGHT GREEN: Right hand turn signal
LIGHT BLUE: Turn signal main
GREEN: HORN
BLACK/WHITE: GROUND
WHITE RED: to Rectifier
WHITE BLUE: to alternator
On the other hand the aftermarket switch has:
DARK BLUE: LEFT TURN
RED: TURN SIGNAL MAIN
LIGHT BLUE: RIGHT TURN
GREEN: SPLITS TO 4 CABLES
GREEN 1 to HORN
GREEN 2 to Light Signal
GREEN 3 to LIGHT SWITCH
GREEN BLACK to LIGHT SWITCH
WHITE BLUE: SPLITS TO 2 CABLES
WHITE 1 to LIGHT SIGNAL
WHITE 2 to low/high beam
GREY to HORN
YELLOW to LIGHT SWITCH
BLACK to low/high beam
I will really appreciate if you can help me with the wiring if this is possible to be done with this switch.
Thanks a lot
YELLOW: HIGH BEAM
GREEN: HORN
BLACK/WHITE: GROUND
GREEN 1 to HORN
GREY to HORN
Thanks a lot
