GS550
cafe1253
Hi guys this is my first post been lurcking for a while
I have a 1981 suzuki GS550t
So far I have made the seat from my old tank cut it in half welded it on.
Polished up the front fork got clip on bars, next need rearsets
The tank is off an ducati
Hey dude,
Nice project! Going to start a build thread? It's hard to tell from the pics but I think your tank is a Benelli Mojave 360.
Yea going to start a build thread get some peoples opinions.
And yes you are rigth its not a ducati tank looked it up last night its actually a 260 same thing though
Anyways anyone have a gs550 project any ideas on rear sets????
Get a set of GSXR pegs and brackets and add a couple of tabs to the frame to bolt them to.
lets see some pics of your 82 need ideas for battery box and rear sets still
thinking of putting the battery under the seat in the back or right behind the carburetors.
I dont have very good pictures of either, but I put the battery under the bum stop. I left the rear mud guard, and made a little tray that I riveted to it. There are two posts on the frame just over the center line of the rear wheel that I used to support it. I ended up having to bracket the battery frame to the bracket that attaches the seat pan latch.
For the rear sets I used one of the stock side plate mounting points for the peg, and machined the arms. On the brake side I cut the brake pivot and welded a small arm, connected with rod ends. The shifter side was straight forward. The side cover plates I just cut all the unnecessary metal off of them.
Cool build. The seat came out cool. Are the clip-ons upside down? I've never seen "upswept" clip-ons before.
Have a color scheme in mind?
Ya the clip ons are upside down havent gotten around to flipping them was fooling around one day.
As for colors I am thinking either all gray black frame and black wheels
all red with white stripe down the middle black frame and black wheels
or red front fender white tank and rear and black frame and maybe alloy colored wheels
MAKR
Where you put your battery is what I was thinking of doing but I really want to make it so I can take the cafe seat off and put the stock seat or something like it back on so the GF can be on the back when she wants to.
I wonder if I can find a flat battery?? well like 3 inches tall
Well I am finally thinking more about paint what do some of you guys use for paint? Duplicolor is really the only paint I know of, what else is there and what do you guys do for clear on your tanks I have read some stuff on gas peeling paint and what not. Any help would be appreciated
I'm all for Duplicolor. That and their other line, the VHT paints. Both are quite nice, and I've even used their pre-mixed stuff that they sell for shoot with actual paint equipment. Worked beautifully, and wouldn't hesitate to use it, again.
I used duplicolor on my goldwing. Rattle canned it. Keep sanding and painting till your satisfied. I originally used VHT white engine paint on the block and it yellowed in about 200 miles. Had to pull the motor to replace my brand new stator so I switched to duplicolor engine enamel and it still looks good after a full season and 4500 miles. Used the duplicolor clear coat over the white. It doesn't look like $2500 paint job but there aren't any runs and it polishes up quite nicely thank you.
