Handle Bar Questions
motormayhem
Active Member
In the process of changing out some stuff on my CB360 and have a few questions. I'm switching from stock bars to euro style bars while I have everything apart. I have removed the old bars from the bike/pulled all the wiring out.
Now come the questions. I need to remove the left grip so I can install it on the new set of bars. Is it glued on or how is it attached to the stock bars? Also I accidentally pulled the wires out of the back of the clutch switch. Does that little switch come out of the clutch lever so I can repair/replace it?
Thanks,
Miles
you can get the left grip off by making it more flexible by soaking it in a bowl of hot water or try to get some penetrating oil in between bars and grip.
for the switch i have no idea what you're talking about, maybe a pic of the problem?
I know the switch you're talking about. If you've pulled the wires out of the switch, you'll have to either take apart the switch and resolder them or replace the switch. The good news is that the switch is still available from honda for about $10-$15. To get it out, you'll have to remove the clutch lever from the rest of the control and push the switch out from the side where the wires were. So you're pushing from the hole where the wires came out, towards where the lever bolts on. It's just a friction fit. No glue or fasteners.
If you're asking this, it's likely worthwhile to let you know you should also glue the grip back on when you replace the bars (I'm assuming you left the grip on the throttle tube on the other side...). Any moto shop will have some kind of grip glue.
A hair dryer or a heat gun on low heat works wonders for loosening up a stubborn grip, I've also had good luck blowing some compressed air under the grip.
Cheers
Compressed air between grip and bars.
The switch is a safety so the bike wont start with clutch not in. Fuck the switch, loop it.
Got them all installed. I narrowed the bars 1.5 in on each side to make it fit where my hands naturally fall when riding. It was a great idea until I went to install the master cylinder and had no room for it (hit the tach and needed to be mounted on the bend in the bars). I ended up shaving it in every possible place and managed to make it fit with about 1/8" of clearance. Once I find some more money I'll be making a seat, taillight, and turn signals for it. Also just left the clutch safety switch disconnected for now….the starter one way clutch is broken anyway so I guess I'll just fix them both at the same time or just pull the starter and make it faster haha.
