HD bobber/touring glide conversion
JRK5892
Over 1,000 Posts
slow morning at work so i figured i would post this up...
I know there there are not many HD's on here... but i work on mine all the time... i am in the process of converting it to a touring bike, so i can run it stripped down when i am around town but then clip on the full fairing and bags and just head off with the buddies... ALASKA HERE I COME!
anyway... here is the progress i have made so far... (this will be a long build as i got a ton of things going and mine takes a back seat)
Custom powder work will be done to all the tins afer i am done, and some custom airbrush work. motor has a 211 cam, VH pipes, Race tuner (right on point), BCT baffles, stage 1 race intake w/K&N filter, heavy duty clutch springs... 110 bore build will be done in a few months after i scrape together some more $$$$...
lots of custom powder, i did my wheels in gloss black hoops and hubs and laced in twisted stainless spokes, tapped my lower trees for fog lights, LED kit, LOTS of custom CNC workd parts, progressive front springs w/ heavy weight oil, air ride, wide tire kit (180 nothing crazy)... ahh there is too much to list, this is my daily rider
here is what i got rocking so far
this is how she sat stock:
after i got done with it:
first step to the conversion... get a fairing (got a outter fairing off a wrecked ultra and will make that work)
got it,
headlight needs to be bigger... so i got a 7.5 headlight that was all banged up... cleaned it up and powder coated that
even tapped some red LED's in the bucket so the headlight would light up
i then dropped in my progressive lowering springs and added the heavy weight oil... well i crushed my front fender on my fog lights on a pot hole... so i had to re do that:
last night i made up my rear fender... basicly re molded my stock fender support and rivited that on the lid of a fat bob fender.. well since i popped in my new progressive lowering springs my fogs smashed into the fender and dented the hell out of it... not such a bad thing as it was black and was half a$$'d anyway... well i finally got some time to turn a wrench or two on my own scoot and tackled this tonight
Used the good old stripper tank and stripped all the paint (B17 makes quick work of paint) thanks Sean for letting me dunk this sucker real fast
I marked out the dents with a marker cause without the paint they do not show up as well. I was able to flat hammer and rubber mallet the dents out... from here i rivited the fender back on real solid.. you will notice that i moved the support forward about 2.5 inches to have it swoop the tire a bit more, i filled the old holes with rivits as well.
after i got the fender locked on there i moved to making it work on the bike
first step was to tape everything up so i dont scratch it, I layed some heavy weight ext cord on the tire to give me my gap (i do this on every fender i slam and it works great, so does fuel line hose)
next was to mark the holes, just so happens that the top hole lined up the the bottom one on the down tube perfect so i lucked out on that one, i maked drop dead center on the top hole on the fender after i got it perfectly strait, put a 1x2 behind the fender support and smacked it with a punch, then i drilled out the holes to the sizes i needed... the excess i cut off and rounded out on the belt sander
cleaned up some of the oxidation on the wire wheel and got it on there!
LOVE THE LOOK!
today i have a ton of running around to do, Sean (www.thepowderpro.com) is going to hook it up and blast it all down, lay a coat of KL primer powder on it so i can sand that down a bit to ensure that the dents are completely gone and smooth, hit it with a color match to the black cherry and 150% gloss clear... wire back on the LEDs under there and be good to go! Now after my buddy finishes up the welding on my rear fender ill do the same to that... hope to have that done some time late this month
this will let me slap a 120 up front and have it completely under the fender... for the rear fender i took 2 st bob fenders and made 1, we cut a section out of the "Chop" fender he welded that into the tail light hole, i brazed that in to fill in any spots that where uneven... now he is cutting 4 in out of the "chop" fender and adding that to the end of the other one... ill use a flap wheel to grind it all smooth. the final product will all my rear fender to be an extra 4 in longer and completely smooooooth... all metal so i can powder... then i will custom powder all the tins. some custom airbrush work from a buddy in KC, of a pin up girl laying on some dice wiht her legs going all the way up my rear fender... i am STOKED...
we are doing much the same to my girls dove tail for her bobber as well.
It's gonna look awesome man! Was talking with the wife last night after test riding a buddy's screamin eagle ultra...thinking I will probably be going the HD route on my next touring bike. Always dug the FLHXs. What pipes are you running?
next step is to get some bags! GOT THEM! tracked down an AMAZING deal on ebay for a set of old 70's FLH touring bags... got the make some quick release hardware still but this is them next to the bike... the prev owner shot them black cherry already... not spot on but close... i will be reshooting them for the exact match
for now when i tour i have a fatty thick solo seat and blacked out shield i toss on there... as well as GPS and a fork bag stereo i made so i can blast out my fav music as i rip down the road
my buddy rocks a BMW adventure so i have to keep up with that on the long trips!
quick release set up for power to GPS, ciggy lighter, and stereo
link to hear the fork bag stereo i make
http://www.youtube.com/watch?v=0jGYwuWw-jA&feature=channel_page
thanks man! the pipes are V&H big radious... got to have the BCT baffles in them to allow you to make some real power and get good torque but they rock.. i powdered the heat shields in gloss black
Jrk, you do great work. But I would have purchased one of these. Wait, I do own this model. That way you could have a bar hopper and a touring bike. Keep up the great work, I looking to do some black on my Street Glide.
I LOVE those wheels man! tell me, do you still have you stock windshield by chance? want to sell it!? you should def do something wild with those wheels wiht powder... they are a great start!
Dude how many energy drinks do you go through a day ;D LOL youve got some energy!!!!
If you were any sort of real biker, you'd finish up that little cafe and take her to Alaska :)
My dad just came back from a 3K mile ride. OKC-->>Houston-->>down the gulf-->>Fl--up to NC and back.
--Chris
ha ha ha chris riding the cafe with my balls crushed up against the tank and seat would make "less a man" of me in no time, ha ha ha ha
Andy... i think i keep monster in busn single handledly! ha ha ha i just do not require much sleep... 4 hours a night and i am golden... uless i squat the day before then i need a full 8 hours... other than that,when i get tired i just go to the gym, get a good run/lift in... can get back to work!
I love what you've got so far. I just wonder if it wouldn't be better for your comfort to have a second set of bars that are a little lower. I don't know if you wrote that in already (at work, can't read everything,) but I think you'd find on the super long hauls you would have a little better blood flow in your arms if they weren't raised up so high.
and you know thats right! i got 2 other bars actually, 1 set of beach bars and 1 set of flat trackers... i set up my interal wiring so that i can just unplug my bars, take off the levers and throttle, put on the new bars, plug them in, replace the leavers and throttle and be good to go... the other 2 bars (beach and flat trackers) will also be internally wired and have the control buttons on them as well as the clutch side grip, so the total bar swap will take about 5 min total...
the apes are actually really nice for long rides but anything over 9 hrs my shoulders start to get a bit tight...
see that, great minds thing alike!
here are the flat tracker bars after i powdered them... still have to lay powder on my other set of bars
Lovin it Joe, just lovin it! Man I don't know how you do it ??? I question wether you even get 4 hours a night. Oh man to be young again!
the tracker bars look perfect! So you got three sets of bars all wired for plug and play for this bike...man you could bring them along as you go to shows on your trips and enter your bike in a category three times, just switching out bars for different looks!
LONG NIGHT! new shocks are on 412 (11in) progressives, black on black! new fender is on (took some convincing and i had to redo alllll the LED's to the front of the bike to make it clean and flawless but worth it) it jsut hugs my tire so tight! looks sick, all the LEDS are wired in and solid, K&N filter is clean, breather bracket is now powdered to match the tins... ready to rock! ill get some pics tonight, did not get done till 3am, and had to take it for a scoot to test it out...
JRK5892 said:
ha ha ha I love bikes man! if it has wheels i will try to own it!
I understand your addiction :-X
*runs into my basement to continue polishing my clutch cover before going to sleep*
