HELP can't remove spark advancer cb350
SONICJK
Reminds me of...me No, I'm sure of it. I hate him
As the title says.
Bolt it removed.
I have soaked overnight in on blaster,
Heated to red hot with a torch etc.
I cannot get this thing off.
Any genius ideas?
Thanks
Sorry. Patience is the only advice I really have. Soak, wait, heat, tug. If you do a quick search you'll see it's very common for these to be a PITA to remove after 40 years. One good trick that works in separating all kinds of stuck parts is to heat it up really good and then spray some penetrating oil right where the two pieces are joined. The cooling effect of the heated parts helps suck the oil into the expanded areas. Works like a charm most of the time.
Thats precisely what I did...
Nothing :-\
So I cut the cam chain so I could finish my diassembly, and the whole assembly is soaking in PB for the next week before I try again.
I have never seen anything so stuck. Red hot, cooled, coated in PB, red hot again, nothing.
Okay I have tried everything I can think of.
Are there any more ideas? This thing will NOT come off.
Its been heated, cooled, jerked, yanked, forced, etc and nothing.
Same exact thing happened to me over the weekend. If you look close at the pic -- you'll see where it had barnacled itself on. I had to sacrifice it -- took it down to the plate then pried the thing off. Kind of a spaz move but mine wasn't coming off either. Cleaned the area up a bit then off to eBay with $15 for another advancer. Dropped a few Fbombs in the process too.
I finally got mine off.
Here's how
Still need a new one though, pretty sure I screwed that one.
When you get your new one, make sure you ask the seller to measure up the diameter and match the stamp number. Some people think they have the advancer you need and have no idea if it will fit or not. Nothing will piss you off more than waiting for a part for two weeks only to find out it's the wrong damn part/size....
I ordered one from an sl350 from the same year as mine.
Should be an easy swap.
Doing a complete rebuild for a daily rider. Had to remove it to tear down the top end.
Build thread below.
One day electronic ignition, just a fresh start at the moment though.
