Help.....stuck clutch sleeve
Bill005
I am changing the clutch in my bike and ran into a problem. I have pulled the clutch assembly but the sleeve/bushing/spacer (whatever you call it) is seized on the shaft. i tried a few things including a little heat (afraid to use too much) but still will not budge. Anyone have any tricks that would work.
Thanks
on ya it is a 77' XS500
more heat... first id soak in penetrating lube.
you really cant get it TOO hot. try tapping it with a hammer slightly.
Bill005 said:
ok thanks. I was worried about heating it up too much and wrecking a bearing or seal
rubber seal youd have to watch out for... but if the thing is that stuck on there anyway, then you would probably need a new seal anyway.
