Honda C95 signal problem
meningitis
hey there.
this is my first post here. just found this forum, lots of good info. was hoping someone could help me with a small issue with my c95:
the signals go solid when stopped or in neutral, but dont blink. they do blink however when running (not normal right?).
was thinking a new relay would fix this. got one listed on ebay but seems like the wrong fit. the relay in my bike is like the one in the first pic (all silver). the one i ordered is like the one in the second pic (the 2 prong).
does the 2 prong relay somehow fit into the silver cylinder relay? are they totally different relays for different models? am i completely missing something with where the 2 prong one goes? i think i need to order a new relay like the cylinder one, and that the 2 prong is for another model.
but any help or advice here would be really appreciated. i want to get this mean little machine on the road, but my mechanic wont safety it until the signals blink all the time!
thanks in advance and hopefully see you guys on the road. oh and its a 1961.
First off, welcome to the site!
When you say they go solid when stopped or in neutral, are they really dim? Might be a problem in the charging circuit. A new relay probably won't help, but for future reference check out www.superbrightleds.com
The new 2 prong relay should work - you'll just need to crimp some spade connectors on you existing wiring.
Indicators going "solid" at low revs / idle tells you that there is not enough current to trip the relay. This could be a battery on the way out, or just the relay being defective.
thanks for responding guys.
set up the 2prong relay with some spade connectors as suggested and the signals now work....BUT, when they are engaged the headlight shuts itself off. frustrating. im starting to think it may be my mediocre aftermarket battery. i ordered a correct relay replacement tho, and if that does not work, a new battery it is.
thanks again....
meningitis,
Just wondering, before all this happened, did you by chance do any rewiring or disconnect anything and then put it back together (before you noticed blinkers not working properly)?
