How do I remove the lower rear guard?
Shooter
76 CB550
How do I remove the lower rear wheel guard? (splash guard)
I have the chrome upper one off but the plastic lower one is a bit of a trick.
I think it is just held in place with tabs on the frame - once the two bolts are removed that hold the chrome fender on, it should pop out I think.
You can download all the service and parts manuals on the site - every nut and bolt is drawn out for you there.
Yeah, it is held in with tabs and appears that it woud slide DOWN through the tabs if the swingarm was not there. It can not slide UP because of some restrictions in the edge shapes.
Maybe it will warp a little and bend inwards. ( Have you guys with no rear guards retained it ?)
I have the Service Manual etc but it doesnt give tips on matters such as this unfortunately.
When I removed my rear fender on my 550F I left the black inner fender in place - it protects all the electronics.
I got it off (quite easily once I had removed the battery box) and will replace it because it does serve that purpose as you say. Thanx
