Simple question; my carbs are 46mm on the inside, what size pod filters should I need? Do I go for a pod with a 47mm inside flange diameter and fit them, then tighten them up?
+1
If the outside diameter is 48mm, go for the next size up. That way you compress the rubber when you mount the pod, not stretch it which can lead to cracks.
