hydraulic front brake perch
Rimmy
I'd like to change the brake and clutch levers on my CB350 but I'm hitting a snag. My clutch is obviously a cable perch and those are rather universal, my brake, however is a hydraulic disc up front. If I picked up a more modern hydraulic perch off of ebay would I just have to get the correct banjo bolt to go from perch to my stock lines if I'm reusing them? Also, does anyone know of any problems with the amount of pressure generated between the newer levers and the older ones, or are the probably comparable?
-jordan
kawasaki ninja, aka EX250.
matching clutch/brake lever, master cylinder is about the right size.
the levers are long though; might want to get the ex500 perches, and then get aftermarket levers for that.
thats your best option, or really anything off a smaller scooter will work. look around. anything with a single front disk should be fine.
I've posted about this a few times, there are basically only two different metric threads, 10 x 1mm and 10 x 1.25mm.
If you find the other thread it will have some explanation (can't be bothered to type it out again)
All M/C's have their size stamped on them somewhere (either in MM - 12, 14, 16 or imperial 1/2, 5/8, etc).
Get one that is the same size (or slightly bigger) than the one on your CB and it will work (a smaller one may be too spongy).
Also, new (braided) lines will help heaps ;)
Rimmy, PJ covered the size of the banjo bolt issue and Hillsy hit on the bore issues. It is really important to get a master cylinder with the correct size of bore.
Too large or too small and the pressure and volume will be all wrong and you brakes will either cause the front wheel to lock or to need excessive pressure to get it to work. OEM is not always optimal either, but it's a good place to start. The outside size is not the issue it's the bore which as Hillsy commented is normally marked at 1/2" or 5/8 or 13mm etc. Modern brakes are 16 or 19mm, older bikes need 11-14mm as a rule.
