If front forks are bent, should I replace the lower tree (CL100)
v30magna
Well I'm stripping my CL100 down, and I've noticed that the front forks are bent. Seem to be bent back fairly equally. Do you guys think the lower tree is fine, or should I replace it too? I know the upper is fine.
Its a cast piece, so if it was damaged, it would crack not bend. If its really a worry, take it to a local machine shop and ask if they can MagnaFlux it. That'll let you know if its been damaged.
its more likely the forks have bent below the bottom triple clamp, once you've taken the forks out, take the top clamp off and see if the holes still line up when you put it next to the bottom one,
lets face it, the forks in a CL100 are going to have the structural rigidity of biro springs at best so its unlikely they'll have transferred any major damage to the clamps
I'll wait until I get some new tubes to see if it's bent. I'm being positive though. Maybe the tiny little tubes just bent, leaving the rest in good shape.
