Maritime
Over 10,000 Posts
OK, on my ride to and from Mid Ohio this year my 30+ year old Front brake master shit the bed and started leaking fluid. I made it home with the brakes still working but ordered a new aftermarket for the bike as the rebuild kits were 2-3 times as expensive. It arrived the other day so I got it swapped out last night:
Removed old, swapped in new, added fluid, pumped a couple times untill air stopped coming out the return hole. All seemed good. went for a short ride and the brakes locked up on the front and got hot. Came home blead some fluid out, then the master wouldn't pump at all? So I pulled the line, drained it, drained the line, reattached filled and blead and it seemed to work ok, except it now pulls all the way to the grip and stopping power is reduced to about half. So my question is, did I not get all the air in the line and do I need to just keep pumping the handle and working the air out? or is the aftermarket MC crap and I should have bought a rebuild kit for the oem honda. 79 GL1000 dual setup similar to all the same generation Honda dual disk single piston caliper setups. One hose to a divider at the forks then 2 to the calipers. I have blead this sytem successfully once to change out the old fluid this spring, I may try that again tonight to see if it improves it and gets any trapped air out.
cheers,
Maritime
cheers,
Maritime
