Is A Valve Tool Necessary
dcwp
Coast to Coast
Pretty straightforward question. I'm thinking of doing a valve job on my CM400 soon, but I've never removed valves before. I see that there are special tools for doing this and the service manual warns that this is very difficult, but it looks straightforward enough.
So the question is this then - do I really need a special (specially-priced) tool to pull my valves or is there a simpler way? Or is this one of those deals where someone who doesn't already know this shouldn't be messing with valves at all?
Thanks!
i wouldn't do it without a valve tool, but i also don't know of any other way of taking off the springs. they are a bit difficult to get back on, i needed an extra set of hands.. i just borrowed a friend's. be careful, they could take your eye out!
just make sure you label them left and right intake, and left and right exhaust.
why do you want them out anywho?
also, try harbor freight for the valve tool
Disasembling the valves is a rather easy task. Just get a socket the size of the retainer and place it on the retainer and hit it with a hammer with medium force. The valve keepers will pop out after a couple of good direct hits and then the valves just come apart. For reassembly, you should probably buy some type of valve spring compressor tool, or make your own. If you look around you can probably get one for around $20, $30 easily.
autozone has a tool rental program and the valve tool is on the list. While not every tool is available through the rental program, the program is truly awesome. The reason why is because its absolutely free. You pay for the tool up front, but you have 90 days to get it back to them and they refund 100% of your money.
I have the same problem on my CM. I need to replace the valve seals. I want to do it with the head still on as I don't think I need any other valve work. I have a spare head I have been trying the procedure on before I do it on my working motor. The hammer and socket is excellent for removal, just stuff some paper towel, damp with WD40 inside the socket to help catch the keepers, otherwise they go flying. The hard part is putting the springs back. I have yet to find a valve spring compressor that will work without pulling the head. That part won't be an issue for you if you are replacing the valves, you have to pull the head. You can get the tool shown in the clymer manual for 20.00 at Princess Auto (The Canadian Harbour Freight). So it should be about the same price State side.
If your looking for a spring compressor that will work without pulling the head, check this one out
http://cgi.ebay.com/ebaymotors/SMALL-ENGINE-VALVE-SPRING-COMPRESSOR-BRIGGS-TECUMSEH_W0QQcmdZViewItemQQ_trkparmsZ65Q3a1Q7c66Q3a2Q7c39Q3a1Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem5d256558b0QQitemZ400059357360QQptZMotorsQ5fAutomotiveQ5fTools
I bought one of these for my KZ400 and it works alright, also if you do a search on ebay "briggs valve spring compressor" you will see a couple more of this type of valve spring compressor. There also nice, because you can adjust the spring compressor for different width springs.
I just put a bid in yesterday for one of those, glad to know it will work! I wasn;t sure it would be strong enough as I have worked on lawnmowers etc and I can compress those valve springs by hand with body weight. Can't do that with the double springs in the bike. I tried the link you sent to buy it now but the company won't sell to Canucks :-( found the same tool from someone else on auction and I hope I win.
Thanks for the info. I just notices I am loosing oil out of my tach cable so i have to check that when I get home form work and see if the o-ring is shot. Between there and the valve seals I hope to stop the use of oil, or at least slow it down.
Cheers,
Thanks for the ideas. I was asking because I see that there are special Honda valve tools and I wasn't sure if I could get away with using a universal, but it sounds like I can.
I want to pull the valves to clean them and check guide clearances, etc. I've got an extra head that I am planning to prep for the bike since the friend who gave me the bike said the old one had damage from running on rusty gas. So pulling the head is a non-issue
I guess the question I should maybe be asking is what kind of work you would do on a head that you know nothing about. Got it on e-bay for a song with the description "came from a working bike" but that could mean anything. I figured if I cleaned the valves, checked the clearances, and put it on with a good gasket, I should be good to go. Anything else I should do while I have the head on the bench?
Thanks again!
OK, I went out and grabbed a valve pulling tool - a universal one from Harbor Freight that looks like this one http://cgi.ebay.com/KD-2078-UNIVERSIAL-OVERHEAD-VALVE-SPRING-COMPRESSOR_W0QQitemZ110304313979QQcmdZViewItem
Now, is there a trick to getting this sucker to work? For the life of me I can't get the jaws of this thing to fit deep enough into my head to pull the bottom of the coil. On the exhaust side I can get close, probably close enough to get the keepers off. But on the intake side, I can only get it on the second or third coil at most. Is there a trick to getting the jaws in deep enough or should I just be using a different kind of valve tool.
Sorry for the remedial questions. This is my first head overhaul.
i've got one like this
http://www.motionpro.com/images/enlarged/08-0247.jpg
Ah, yes. I see how that would be better. I'll check at Murray's in the morning to see if they can loan/rent me one.
Thanks!
