Is this normal?
Lone Wolf 87
I know every bike has its quirks. Like how older harleys and triumphs leak oil from time to time. I have a 1972 cb750 and when I leave it on its kickstand it leaks gas/oil from a nipple on the bottom of the floatbowls of the carbs. Only on the left side though, which is the direction the bike leans. The original owner told me that that's normal. Did he blow smoke, or is that true?
I have the petcock set to stop, so I'm assuming it's one of those things you mentioned. Thanks for the help! Now I just gotta dig in there.
A gasoline leak is always abnormal. If you park your bike in the garage, you are spreading gas fumes in your house. You should really fix this before you have a fire.
The possible causes have already been mentioned. My first guess was slightly high float level, but leaky float bowl gasket is a good culprit also.
If the float is brass, there may be a pinhole. Dunk it in water and see if there are bubbles.
Don't know if the 750 is the same, but the 550 has brass overflow tubes which very commonly develop hairline cracks, causing leaks. Something to investigate if you've exhausted other options.
