issue with left running light, CB550
lzwartve
I have gone thru two new bulbs on my left running light on my Honda CB550. Initially the light works after I replace the bulb, and then within a couple of weeks the light wont turn on when i turn on the bike. The blinker still works, and the right running light works. Any ideas as to what could be the issue?
wtf is a left running light? is it a forgotten bulb that runs on its own, chasing you because you left it?
Get a multimeter and test the voltage your bike is putting out. At 5000 RPM it shouldn't exceed 14.2V.
lzwartve said:
Good one Albert. You know in the USA Jan is a girls name
You know that when you type like shit, you get shitty answers?
How can we help if you don't provide the right info?
By the way - Bert Jan is BJ for short. That would have made a better joke.
And Sonreir is just trying to be nice. The battery voltage should be 14.2 max, but that does not have to be the issue for whatever problem you're having (cause i still don't understand the problem...)
You say the right one works, so i suppose you mean your turnsignal bulb? If the other bulbs don't break, i think your voltage is good. IF it exeeds 14.2 more bulbs would blow. Not really logically that only one turnsignal bulb gets more voltage then the rest of the system.
It could be that the bulb sits a little loose in the fitting and vibrations may cause the filament to break. Bad grounds also help shorten the life of bulbs as they will get a uncontrolled voltage flow constantly. bulbs like to have a constant voltage on them.
Sonreirs option is also a good one, but put the wires of the multimeter on the fitting inside the turnsignal holder. If the voltage goes above 14 you know there's a problem. I doubt thats it, because you say you can ride a couple weeks with it before it breaks. That's a typical symptom of loose bulbs/bad ground.
check and report please, so we can help you further. And don't bite the hand that feeds you ;)
I'll be the first to admit that I am totally green when it comes to motorcycle repair and jargon. I also admit the BJ joke would have been better.
Thanks for the suggestions. I'll check the voltage and bulb connections when i get home. Appreciate the help
just to poke fun at BJ up there, it is in fact called a "running light" ::)
way to be a sport though.
wich light are we talking about anyway?? A running light? Is that the light that goes on once the engine starts? I've never heard of a running light :)
yep - in a two-filament turn signal bulb, we call the one that turns on with the bike a "running light".
Are they located in the speedo and tach then? green and brown/white wires? Else, i guess thats an USA mod as we don't have those lights on the bikes over here.
Funny, ol BJ made me feel like a buster. He came around at the end though with a good suggestion
Well, I think I figured it out. I took the bulb out and tested the voltage with my multimeter, tested 13.5 which was good. All of the connections looked good and the bulb connection was clean. I was stumped. So I took apart the right blinker/running light and it looked the same...until I took out the light and noticed it was a tad different. Turns out the previous owner of the bike replaced the left bulb with an 1154 dual filament, but the cb550 from this year needed a 1157. Small difference but big enough so that the bulb didn't have a tight connection and would burn out. When I was replacing the lights I was just matching the existing light.
So after buying and replacing the light with a 1157 I haven't had the issue. Thanks for the help and I'm glad I could help teach BJ about running lights
