kevineleven
So I sourced a set of (used)CR33 specials at a very below market price. My initial thought is that it may be a bit too much carb for my DOHC cb750. I opened them all up to see that everything was there, and the jets matched, nothing gummed up etc. All was in order so I made up some fuel lines and mounted them. FYI, I've never dealt with CR carbs before, so I expected a learning curve. They pissed gas everywhere, so I took them off, cleaned and tightened all that could be cleaned or tightened, and no more fuel comes from places it shouldnt. Crazy hard time getting a good start and idle, so I threw on my mercury sticks and proceeded to get a good sync on them. Now, idles great. I expected (and was told by the seller) to roll the throttle on, rather than cracking it straight open. This yields decent response, as cracking it straight away yields massive bog. Here lies my issue. The revs dont come down very quickly, if at all when the throttle is released. In the past, I've always related a high or hanging idle to a lean condition related to a possible vacuum leak somewhere. Tonight I removed all 4 boots, cleaned and replaced them and made sure everything was in good order, but I still have the hanging revs. I must say that I'm only using a pull cable, instead of the push/pull 2 cable system thats recommended, but the slides all appear to be returning to the idle position , not held open by the vacuum created by the engine. I dont know where to go next. Help?
