Kickstand troubles
jmal18
Active Member
Hello all, my name is JC and I bought a 1971 cb350 about a month ago. It was a great deal but it did come with flaws as I expected. The biggest issue I am facing is that when the rear sets and 2 into 1 exhaust were put on they completely eliminated my kickstand options...I have a GSXR kickstand that was sold with the bike but it obviously too long. I also just bought a side kickstand from a 1974 Honda. Any suggestions?? I could go to a local shop and have them weld a mount on and shorten the GSXR stand, but I want to know if there were any other options I had not thought of...I appreciate any help!
First of all, welcome to the site!
I just want to clarify - you do mean kick stand and not center stand, correct? I had the same problem w/ my rearsets. I ended up cutting a small notch on the kickstand and also bending it in wards a couple degrees. Some people buy the universal clamp on type and slide then forwards on the frame rail as well.
Yeah I mean kickstand, the center stand mounts are blocked by the exhaust and from what I am told/seen the side kickstand attached to the stock pegs on the CB350s...I was thinking abt the clamp on variety but have only seen them for about $100...this is a budget project so the most cost friendly option is what I am looking for
move the mount forward on the frame, cut the new kickstand, weld in proper short length, mount, make a stop place on the back (rubber works well) and VOILA, done.
I went to the local shop and talked to the guys there, the previous owner cut off the tab that was attached to the frame where the kickstand was mounted. Everyone is telling me that I need to find an old frame, cut off the tab, and then weld it back onto my frame. I am thinking about heading a local motorcycle salvage yard to find an old frame. There was a 77 cb400 in the shop and I saw the tab that I need. I also looked at some motocross aftermarket kickstands but those attach onto square frames and my cb has a round frame. I am tryin to find the best option for my $$$
Why cut one from an old frame, its just a cut of like 1/8 inch steel with a hole drilled in it!!!!!! You should be able to fab one up in about 15 minutes!
If fabing one or having one fabbed is not what you want to do for whatever reason, chech through Dime City's site...I am sure they have something you could use! Thier site is linked at the top of the DTT home page
i have heated and bent them in the past... but the last one i did for my fighter i just cut, re welded it, and powdered...
GSX-R stand bolts to an alloy frame so you would be better off (cheaper) modifying the frame mounting bracket and welding it to CB350 frame.
If you don't have the bracket, should be cheap and easy to find one (not something that usually gets damaged when bike is crashed)
PJ
Well after some thought, I was talking with my brother in law and he mentioned maybe rethinking the exhaust, the pipe on it now is somewhat half-assed. The previous stuffed a 2 into 1 pipe on it but in the process had to hammer the pipe in to bolt the rear sets in...I was thinking about just cutting the exhaust before the center stand mounts and making a GP style exhaust..similar to a Buell...still debating that though, borrowed an angle grinder from my neighbor and going to take a look at welding a steel tab onto the frame
