KZ-1100 1981 valve adj specs, and cam timing.
Scooter trash
I have a 1981 KZ1100, with two tight valves. Anyone know the clearance and how the cam timing marks go? I could count the links from point a to b at TDC #1-4, but doesn't mean that's correct to copy what it is now.
.05-.15mm for in and ex. if you have the shim tool you should not have to pull the cams. heres a link to a PDF manual, its big so it will take a while to load.
http://kz1000r.com/downloads/Kawasaki%20KZ1000%20KZ1100%20Service%20Manual.pdf
