KZ 400 trouble
The max gap you are showing looks fine - should produce a crazy high idling (redline!?) speed, so no worries there. You don't need any sort of guitar string or drill bit. Simply back the idle stop screw out far enough that the throttle plate on the carb that has the cable attached to it is fully closed. Then adjust the sync screw - that's the one you have backed all the way out and the jam nut loose on - so that the "slave" carb has its throttle all the way closed. Operate the throttle grip and make sure that both butterflies just close at exactly the same time - adjust the sync screw until they do. Then tighten the jam nut and re-check. Then start the bike and screw in the idle stop screw until it idles. Remember there is a pilot circuit that will need to have its metering screw adjusted as well - might be a fuel screw instead of an air screw like your RD. If it is on the engine side it is fuel, and you screw it in to lean out the mix instead of out like your RD. That's all you can do until you sync them while running with manometers if you deem it necessary. Bench syncing them as just described will be fine until you get everything else sorted regardless. Doesn't look like you have had them apart. You should know by now that anything less than 100% disassembly is likely a waste of time. You have to remove the butterflies and shaft to change the seals which is usually the worst problem on these type of carbs. Remember, these things are essentially the same as your RD carbs except for the vacuum slides.
Thanks mobius!
Somehow last night I managed to do the exact thing you said,but had no time to restart the engine.
Here are some symptoms that occured when I started last night:
1.)the bike started well but revved up to the sky
2.)I adjusted the idle screw,bike would idle but when I turn the throttle it would die and take no power from the twist
3.)constant popping from the carbs (as if there was too much gas in there)
Closed the 'main' carb butterfly with the idle screw then adjusted the 'slave' carb butterfl to be closed too.
I will make a short video today how the engine will do.
The pilot metering screw are the screws left and right under a plastic piece arent they?
Is there a standard setting i could start from,there's not alot of turns in this screws,maybe 1 1/2 of turns.
A friend with a nanometer gauge will come over the next weeks and we will make the fine tune, for now I just want to get it running.
Thanks!
Victory!
Had some time yesterday after work and got the thing back running right ´ish.
Took of the plastic caps of the mixture screws, and turn them all the way in and 1 1/2 turns out.Then I once more controlled the sync of the butterflies.
I made two videos.
Number 1 shows the first start up after the adjustments above.
Number 2 start up with air screw 1 turn out, tried this adjustment because the carb was making "popping noises", which sounded like it was too rich.
Now it looks like I´m in the ballpark for some further manometer adjustements and balancing.
1:
https://www.youtube.com/watch?v=L72WXiR88Rs
2:
https://www.youtube.com/watch?v=GoqfAcQiGGg
One thing that still boggles my mind is that it looks like one cylinder is running leaner than the other one, maybe its really a question of carb sync but the right hand cylinder plug is brown-whitish and the left one is black and full of soot.
Guess I will need to do a plug chop with new plugs when the carbs are balanced.
Any other idea what could cause this?
It could be down to a load of things:
* dead/dieing sparkplug or any other ignition related part of that cylinder
* mix-screw tip sheared off
* if the black soot is oil, it could be down to all sorts of things...
