Marcus - yes if you're starting with the electric start. In fact it might be necessary depending on what bike it is (some have a switch on the clutch to force you to hold it in while starting the bike).
If kickstarting, then no - the kicker typically relies on the clutch basket to turn over the engine. Really depends on the bike.
Hi it's a hardtail kz400 with a 1980 lump, no clutch switch on it, when in 1st gear with the clutch lever in the bike creeps forward when I press the starter button. Have adjusted clutch adjuster and there was not a lot of movement screw!
