I just picked up new intake boots for my KZ400. The old ones were rotted and the PO had tapped them up as a bandaid but I like things done right. After finally getting the old ones off (the right side screws were stripped out), it looks like there was maybe a dab of silicon or copper gasket put on them.
When I install the new ones, is there a gasket that goes between the head and the boots? Should I use some light RTV on it? I would suspect since the boots are rubber that should mate up tight enough but I guess I'm unsure.
I'm also having an issue with fuel leaking out of the left side carb. I can't pin point where it's coming from, but I pulled the carbs (since I was doing the intake boots anyways), and will check float level and that the float isn't stuck. Is there anything else I should check here?
