KZ440 cafe build
cafemeyer
Love this site!
As mentioned in my "member intro" topic, I have been lurking for some time now. Last year I built the bobber pictured below.
I have now started rebuilding a 1980 KZ 440. I picked up two of them last year. They both started but are in bad shape. I was hoping to make two bikes, but am now just going to use them both for one with some leftover parts. Below is a pic of one of the initial bikes.
I started tearing into the other red KZ a couple of months ago and then got side tracked with school. I now have everything torn down and have started some fab work. Below are some pics to catch you up.
initial tear down (much easier being a two cylinder than the CB500 bobber.
more pics of tear down
More pics of tear down below
most of the electrical take out
back subframe hacked off
clipons mocked up
initial ideas on rebuild
I have been going around and around on what I want to do with this rebuild. First it was a bobber, then a cafe racer, then a drag type looking bike, now I do not know what it is turning into. It does not matter to me. All I know is that I need to get it done so I can ride before summer is over. Below are some ideas on what I wanted:
love the look of this bike
so started designing struts on Solidworks
here is the toolpath for cutting on a CNC machine
above are wooden struts cut out on a Techno CNC router. My plan was to see if I like them and then cut them out of aluminum on a Tormach CNC mill......the more I thought about it, I want to keep rear suspension as the seat I want to make will not have much padding
more ideas
Scrapped the struts idea and then found this pic
love the looks of a drop seat so I photoshopped it to look like the bikes below:
first attempt, mostly color changes
second attempt with different seat and front fairing.
Love the look, but want to get this ride going for the summer so I have scrapped the hardtail idea also and started adding on to the original subframe
Yes, I change my mind on my motorcycles as much as my wife changes her mind in a shoe store, however, half the fun for me is prototyping and dreaming.
tail section
Tried to incorporate a little different tail design. Just bent some 1 inch tubing in some curves using BendTech Software (awesome stuff) and a Baliegh bender (great company) and started cutting and welding. I am happy with the look.
Here is a shot of the stance. The bike looks a little weird because the forks are bent :'(. Not happy about that, but have a good set on the other bike.
mocked up with a Sportster tank and cardboard seat
I know that a cafe racer does not have a Sportster tank, however, I just may try to pull this off. Call it a mutt bike...
seat and new helmet
I will eventually replace the cardboard seat with some sheetmetal and leather. I will eventually build one with the style of the one below I built for my 500 bobber......different shape of course.
Also picked up a new Blade helmet last week. Kind of different looking, but the most comfortable helmet I have even had.
I need to take more pics tomorrow of some recent progress and then I will start again.
thanks
quick question
I started really cleaning the engine last night to prep for paint. Just as I thought, the previous owner used a bunch of gasket sealer to put the clutch cover on. Oil was leaking out all over. I made a new gasket today. What is the best way to put this back on? I have heard of some people putting a little grease on the gasket first....if so, what kind of grease? I have also heard of some people putting liquid gasket on either side of the actual gasket and then putting it on.
Thank you for the help. I hope to get the engine polished and painted this week.
- Steve
more fab work done
Well, school is out so I should be able to get some good work done on the bike now.
I was able to get in the garage tonight and get the battery tray and rear cowling done. I plan on painting the rims and frame black, tank, mocked up number plates, and inside tail section orange, with white on the inside and a black pinstripe.
Tommow I should be able to grind the welds down on the frame, remove the tires, and clean up the engine some. I have to be on the road by the end of the month or I will go insane.
folgers coffee lids to mock up the future metal number plates
turn signals
Love the tail section but I'm not too sure about the sporty tank. I'm also currently building a KZ400 cafe racer. I love the shape of the stock tank. It narrows nicely at the rear so no need to add knee dents.
Thank you for the nice comment. The tail section looks a little rough yet, but after some grinding and some paint, I am hoping it cleans up the look some.
Taillight will probably go with license plate on the left side of the bike. Either attached to the axle of off the side of the frame.
great looking bike, it willl be interesting how it comes out. As I was reading I was getting my thoughts ready to suggest that you leave the tail open like you have, I was then pleasantly surprised that you did by page two . Good stuff. Best luck and I dig the bobber.
Tony
more pics of KZ build
Got to work in the garage some tonight. Was able to fab up the turn signal mounts and the taillight/license plate. Pretty much doen with fab work now besides final welding and grinding. Hopefully I can get that done this weekend so I can paint early next week. Below are some pics....
