KZ750E wiring question.
Medicontheloose
Quick question for the masses. I've eliminated my front signals on my 80 KZ750E cafe project. Is there any need to do anything other than cover the ends of the open wires?
Thanks in advance.
I have an 81 kz750e. I went through the entire wiring harness. If you follow the turn signal wires through the harness, they reach a connection with 3-4 other wires. That's where I'd end the connection
No. Leave the loon intact. You might want to put them back on later (or you sell it and the new owner wants them back..)
Just make sure the wires dont ground to the metal parts on your bike.
You might want to look at your clignoteur (the box that does ticktackticktack). The wattage of your turnsignal system has changed now that you eliminated 2 lights. Could be you need a clignoteur with lower wattage. If the rear lights still work, you're good to go!
