When you say "LED blinker" do you mean that you changed the flasher unit itself, or the bulbs?
When you replace traditional filament bulbs with LED bulbs, they usually will stay lit because they don't pull enough current through the flasher unit.
To fix thus, replace your flasher with an electronic blinker. It will blink the same speed no matter what load you put on it.
If you've already replaced the flasher with an electronic unit and its still not blinking, then you either have a faulty flasher unit or its wired wrong.
