evilaugust
How do I go about this? I assume a resistor or resistors will be required.
Tim said:You mean the flasher indicator? I'd expect it runs off the same power feed as the signals, so if they're working, it should work too. Once the flasher relay is 'flashing' adding LED's to the circuit shouldn't stop it.
