yes i did not mean to high jack the thread either just to possibly add some insight if needed... about 210 degrees the reflector material i used could be formed...any higher it deforms lower no action..i would imagine there are variables so best to experiment . i form a piece of light gauge aluminum into the rear of the seat section first. put in the oven with the reflector on top,once hot enough it will droop, then you may have to adjust it slightly depending on how intricate the part is(where some gloves) and work quick....once set to where i want it i cool it with a water soaked rag..if you need to readjust put in oven again..the material is brittle so do not force it! i have done it with several different pieces of red material,reflector from a hardware store even old car reflector pieces- the one on the ducati above is $3 from tractor supply!..joe@vcycle
