I'm hoping somebody can throw out some useful suggestions for me. I've bought a couple of LED headlights that I was going to mount side by side. The plan was to wire things up so both are powered for high beam and one for low beam. They have a two wire cable, positive and negative. It turns out that they are set up internally so that when power is first applied they light up bright, flash the power and they dim, flash it again and they blink. I really have no use for the blinking feature at all though I have had headlight modulators on bikes in the past. What I'd really like to do is just disable both the dim feature and the blinking feature and go with Plan "A" and light two or one for high and low beam. Since it's most likely controlled by a chip of some kind there probably isn't any way to disable it.
If I can't disable the built in functions I guess Plan "B" would be to use both lights together wired though a momentary contact, normally closed switch. Bump it once and you'd go to dim, then when you want to go back to high beam you have to remember to bump the button twice to skip over the flashing function. This would be a relatively easy fix, but doing that wouldn't allow for use of the high beam indicator light in my DanMoto digital dash.
So, any suggestions? Ideas? Comments?
