LED Questions...
PancakeShake
Alright.
So I have some small bulbs that light up my gauges, I have tried to remove them and replace them with some LED's, however, when i connect the LED and turn the bike on, the LED just gives a very very VERY slight flicker, then goes out. The light flickers again when i shut the bike off too.
Its NOT frying the LED, because it does this every time I turn the bike ON and OFF.
It shouldn't be a resistor problem because if the voltage was to high it would just fry...
Any idea why it might be doing this?
ALSO, I am looking to convert all my blinkers to LED's but im not really sure where to start. I know you need the flasher relay, but where does this go in the wiring scheme? I have seen the 3 prong ones, and assume I need that, but I dont really know where to start. Any tips and/or HOW TO's online would be sooo great.
Thanks in advance!
Where did you get the led's from? I think some are rated for max voltage and others can have polarity issues. Check out www.superbrightleds.com if you haven't already.
And you already have a flasher relay (or at least you should unless it was removed). So find your current one and look for a replacement from the site mentioned above.
I have a few hundred bulbs (Electrical Engineering Dept at school had a ton of extras) but from my experience with them , no matter the voltage, the resistor in front of the LED should be fine.
Another thing, I wanted to convert my tali light to an LED from advanced auto parts, but my tail light has 3 wire coming off of it, thiers has 2. Is that a do-able conversion?
Also, i wanted to swap my headlight to an HID, I have an HID H4 from my previous bike (CBR) but im not sure how to connect it.
It has a large oval plug, along with 2 smaller clips, not sure where those go.
Like this one http://www.ddmtuning.com/Products/DDM-35W-55W-Single-Motorcycle-HID-Kit
Whoa! One question at a time please!
I've never had a problem converting stock 194 bulbs to led unless the polarity was switched. Might just need to flip the bulbs (or connection).
While converting a 2 wire bulb to function as a stop/tail light is possible, it's usually not worth the effort. Check the bulbs at superbright and I think you'll see they are about the same cost as Advanced or Auto Zone.
I have no experience with HID conversions, sorry.
Alrighty, ill give the gauge bulb another go, maybe i had it wrong.
As for a flasher relay, I really dont know what im looking for. Im 99% sure mine is a 2 prong flasher, but there are alot of those on superbrightled.com
The one in my bike is here...
http://www.ebay.com/itm/1982-Suzuki-GS450-LZ-GS-450-S235-flasher-relay-/290699602140?hash=item43af0be8dc&item=290699602140&pt=Motorcycles_Parts_Accessories&vxp=mtr#ht_2186wt_905
but i dont know how to select one on their site
You should be able to "plug and play" the CF12ANL-01 relay from SuperBrightLED's ;)
Any electronic flasher will work.
Mine came from autozone for 13 bucks.
The only difference in a 2 prong flasher and a 3 prong is the 3 prong gets grounded.
Not always. If the third prong is marked with an "E" (for Earth) it should be grounded. If it's marked with a "P" (for Pilot), that wire goes to a dash indicator light. Ground the "P" and you'll blow fuses and/or melt wires.
Some 3 prongs need to tie into the power wire, after the battery.. There's too many styles to generalize :)
