cafechris
Hello all,
I have my rear running lights, brake lights, and left/right signals now working. I tried another aftermarket relay and it worked like I expected. Lesson learned=just because it is new does not mean it is flawless! Now I have moved on to the front signals, which are causing an issue. The PO had the black wire from each of the front signals going to ground. The red wire from each side was connected to the light blue and orange wires respective to side. When I activate the turn signal switch with the front signals connected, the upper right fuse blows immediately. When I disconnect the front signals, the fuse does not blow. Is it wired incorrectly? Do I have to run LED front signals also, are can the OEM signals/bulbs still be used? I have seen plenty of bikes with a LED rear setup and what appears to be incandescent up front. Or are they actually LED's in an original housing?
THANKS!
THANKS!
