I bought some hammerhead shocks that are about an inch longer than stock. the chain is so close to the swingarm pivot that it will slap it while riding. It's a 73 tx650. Anybody else have this problem, how can i remedy this.
The only thing you can do (other than revert to shorter shocks) is put larger sprockets on front and rear. This will lift the chain off the swingarm, but you will be limited by the engine casings as to how big a front sprocket you can run.
Remember that a larger front sprocket makes the gearing taller, whilst a larger rear makes the gearing smaller, so if you increase both you should be able to find a similar gearing to what you have now.
i saw someone used a block of teflon/. not sure if it's recommended, and it surely wouldn't stand up to constant chainsawing, but for the occasional grounding, would be easy to keep an eye on, and replace as needed. also, i think the toothed rollers for MX chains can be easily found on the internet.
I think I need a tensioner, the chain is only above the pivot at full ride hieght, when i bounce on the bike the chain goes slack and is laying across the top of the swingarm. the chain and sprockets are newish, about 400 miles, how loose can I have the chain without it jumping off?
Well, there aren't too many other ways to make these shocks the correct lenght. I'm assuming, and I'd bet I'm right, that the reason he bought the longer shocks was not to raise the rear end.
I'm betting it was becuase he got a good deal on some shocks that happen to be too long for his bike.
So if cutting the springs is a bad idea, what would you suggest?
If he were to cut the springs 1" shorter, doesn't that raise the risk of bottoming out the shocks more? Assuming that the set weight load (whatever it's actually called) of the shocks somewhat matches the bike/rider. God forbid a shock bottoms out and snaps a mount or 2. Just saying.
Cutting the spring effectively makes it stiffer, however there are too many unknown variables to say one way or the other whether or not the bike will bottom out.
A delrin slider could be added to the top of the swing arm or if you're particularly crafty a roller type tensioner could be added. You'll want it to be solid mounted though if it's on top of the swing arm as the engine will naturally tighten the top span of the chain under power so if your tensioner is spring mounted you may not be buying yourself anything as it could just mash down under power.
I bought the shocks longer on recomendations from several roadracers and flattrackers that use this frame and engine. It helps put a little more weight on the front tire. I'm also going to slide the forks up 1/2 inch in the triple trees. Most people use the longer shock on the 74 and newer bike, it has a slightly longer swingarm.
Thanks for the replies, I'm going to try a gear up on both sprockets, the gear ratio remains the same.
