Loose exhaust
arsey
So my cb350's right-side header pipe is loose where it meets the engine. so much so that it gets blackened when the engine is running.
I've since realized that the old gaskets were still in there, and the flanges were on backwards. haha.
but I fixed that up, tightened everything down, and it still has a bit of travel in it.
anyone run into this? can I throw another gasket in and hope that works out?
i've had to mess with mine for a while too. if you got new crush gaskets just make sure that the flanges collars don't overlap and your putting everything in the right way. if your new to this like me ANYTHING IS POSSIBLE. i've messed up a lot of easy crap.
i had the same problem with my cb350 up until only a few hours ago. new gasket, joint collars in decent shape, installed properly etc... after trying out different combinations by swapping out the components from one side to the other, concluded that it must be the header pipe. i put the collar part in a vise a noticed it was moving slightly, cracked in a weird way on the inside. it's now at a friends house waiting to be welded solid.
check it out, could be a similar issue
thanks for the input guys.
figured it out though, the collar where the header meets the muffler was cocked at a weird angle. turns out the muffler wasn't even attached really. once the collar was off I just pulled the two apart.
looks like some emgo shorties are in my future
