NeeksRR
Active Member
So I was getting my little 66' CL160 some love today to go on its first ride from being in piles of boxes months ago.
I got the bike to run and idle ok, didnt bother adjusting the carbs to much, just wanted to get it running. I put on a chain clutch cable so I could give it a little ride to shift through the gears.
When up on the stand Id pull in the clutch and put it into gear, the wheel would not spin. Kept adjusting the cable and still got nothing. Eventually I pulled in the lever, pushed the wheel with my hand it awkwardly "broke" loose and I thought I freed it up or something. I tried to kick it over to get a ride and it totally lost compression, then on top of that every gear moved as it was in neutral with almost zero resistance with the clutch in or out.
Im not really sure what happened...but my guess is its not good and is going to involve opening it up.
Any ideas or constructive advice would be very much appreciated. Thanks guys!
