Low voltage
Slapz
Trying toget an ebay GS550 to run. Completely cleaned carbs and re installed, It started right uo ONCE then died when I tried to blip the throttle. Now spins fast, don't start. New battery that yests at over 12v. Turned on jedlight and was dim. tested headlight socket and only 10v. Is this a bad ground or somthing? The tail light is dim also. Could low voltage to coil affect starting? New to multiple carb jap bikes.
First thing I would do is make sure the charging system is working properly. If that is ok, then start checking connections and checking for bad grounds.
Good luck!
Do you know how to use a choke? There are so many ways to "Completely cleaned carbs", care to share a little more detail? Completely disassembled, pulled the jets and soaked the bodies, blew out every passage with compressed air and replaced all o-rings? Or just pulled the float bowls and sprayed down with carb cleaner.
Have you ran a compression test? checked timing or the valve adjustment?
yes, it is a ground or something... If you have 12v at battery but 10v elsewhere, check connections to see where you loose it, power or ground.
Yes, do you have spark (blue) when cranking?
Welcome and enjoy! ;)
