Magical all in one welder??? Can it be real?
1969Honda
So I've been on the look out for good little welder for a while now, I've got some extra funds finally coming in and therefore the search has picked up a little. My big question is, has anyone heard of the LOTOS machines before? There's one for sale not to far from home but I've never heard of them. Their website http://www.lotostechnology.com/product_p/ct520d.htm seems to promise great results for everything, Plasma/Tig/Stick, but who's doesn't. If someone has any experience please share, I'm wondering about the usual, reliability, performance, short comings, etc... Thanks, oh and the other possibility is this http://www.millerwelds.com/products/mig/product.php?model=M00245
I have no idea if it's worthwhile, but I'd, too, love to know. That's a do-able price for what it's supposed to do.
When you say "hours and hours of duty," are you implying that it will break down quickly, or that it would overheat/shutdown with extended use?
Swivel said:
you are not building a submarine.
Wait...what did you hear? ;)
Yeah, my welding needs are pretty modest. I'm sure reviews will be helpful, too. Thanks.
Thanks for the input guys, I'm just looking to work on my own personal vehicles and the occasional fab/repair on the side for the local farmers and lawncare guys. I can't really see doing anything thicker than .25-.375" at any given time. If it comes to that I'll get out the old buzz box and crank'er up.
That being said I'll keep looking thru the review and see if anyone has anything else to say. It'd be pretty trick to have an okay 5 in1 multi-purpose machine for under $2000 though ;D
Neither machine is particularly well suited for welding aluminum, so if you don't care about welding aluminum, these would be fine.
The Lotos machine says you can "stick weld" aluminum, and the Miller machine can weld aluminum with the proper MIG wire. Believe me, either method really sucks. The only legitimate way to weld aluminum is with a square wave TIG outfit.
I have an inexpensive DC TIG from Harbor Freight. I paid less than $300 for it. (Also had to buy an argon flow regulator, some fittings, and some tungsten electrodes.) It works OK. It has a limited duty cycle. If I am welding heavier material, it will overheat and shut off after a few minutes. Also, the torch handle will get too hot after a while. The cheap TIG has no pedal control, and no high-frequency arc stabilization. It is difficult to maintain an arc at low current, and starting the arc is a scratch start, which is trickier than a machine with high-frequency high-voltage arc start. Still, I have gotten accustomed to the cheap machine and get good results within its limitations.
I long for a more powerful machine with a water-cooled torch that will do aluminum.
Sounds like we have the same unit, mine is made by Century. Got it for about the same money but it does what I want. Can't do aluminum either but that doesn't break my heart. Someday I will come across an old professional TIG unit for reasonable dollars, for now I will stick with my inverter.
Thanks for the input Alpha, I've looked at the HF inverters but have never met anyone with actual bench time on one.
Hey there,
Hope you don't mind a little advice from a new guy... I'm new to this site, but the topic at hand is kinda my area. I am a welding instructor by occupation. The machine in question...not too sure about it. I have been welding for over 17 years now and I have never come across a welding machine that does as much as this one claims to do. Not one that is worth salt anyways... A good multi process welder will be capable of welding CC or CV welding processes (Stick, TIG and MIG). I have never seen plasma cutting thrown into the mix. As far as the brand, never heard of it... That doesn't mean I have seen them all, but everywhere I have ever worked has never had one. That says something to me. The big players in the welding game are Lincon, Miller, Hobart, ESSAB etc. Those are the only ones I would trust or even consider. More expensive...yes, but with welding power sources, you get what you pay for. Even for short time home use.
The "duty cycle" everyone is referring to is based on how long that machine will run at max output in a 10 minute time cycle before needing to stop welding or the machine will overheat and go into a thermal shutdown state. (eg. 200 amp machine with a 20% duty cycle is good for 2 minutes of welding at maximum output) Not a huge deal to most home or hobbyist welders...but not suitable for industrial use. All of the major players in the welding machine industry have a model to fit just about everyone's use, requirements and budget.
Again, I hope I'm not speaking out of line, and please take my opinion as just that, an opinion...but go for a name you have heard of and get the best you can afford... It will be easier to use and learn on and will save you a lot of frustration in the end.
If you did already purchase that other machine, good luck with it...I really do hope it does what you ask of it. Let us know...
Thanks Dave, no offense taken. opinions are always welcom! I decided to hold out and am going to save pennies for a miller, I used to work at a small fabrication shop building snow cats and doing prototyping for a mechanical engineer on a 212. I totally agree on the big name brand, get what you pay for theory when it comes to any piece of shop equipment; I was more curious if this was a big player out side of the US and if so what their reputation was.
