Metric Rod
SkiMan
Active Member
Does anyone have a good source for metric steel rod?
Using metric dies on standard rod just doesn't do it.
Looking for 5, 6 and 7 mm in 3 or 4 foot lengths.
Haven't been successful in tracking any down here in Connecticut.
Purpose..... making some new linkages.
SkiMan
Is this for rearset linkages? Have you considered getting plain unthreaded rod and getting a tap/die set to thread it yourself? Might make for a cleaner look rather than using all threaded rod.
I'm looking for just plan straight metric steel rod. I don't want threaded rod as I'm using it for the rear set linkages. I've got the dies for the left and right threads, now I just need the metric rod. Looking for an online source that sells small quantities.
SkiMan
Maybe try aluminum rod? Softer so dies will bite in easier. Not as stiff but if the linkage rod isn't too long, it should be okay.
Thanks for the sources guys. I'll check these out.
While I would like to use aluminum, I don't think that there is the availability in metric sizes like there is in the steel rod sizes.
SkiMan
theres plenty of different sizes to pick from on the site i supplied.....seriously it is the best site for raw materials hands down, check it out.
