Mikuni CV carbs
rudy
If it don't fit, you're not trying hard enough!
Got my shipment from Z1 enterprises today, along with a Mikuni carb tuning manual. Very nice book. Includes info on VM Roundslides, VM Smoothbores, TM/TMX Flatslides, HS Flatslides, HSR Smoothbores, and RS Smoothbores. They failed to include the BS Constant Velocity (CV) carbs that were so popular on the old XS bikes back in the day. Imagine how disappointed I was. So, I've spent the better part of tonight looking for something, ANYTHING online about tuning any size BS carb. The 400 has 34mm and the 650 has 38mm, basically the same thing. So, I was just wondering if anybody has a tuning manual for these things, or if you know where to get one. Mikuni doesn't even list these carbs on their site. I'd like to either buy a hard copy, or download a PDF if possible. Would it even be worth it to try to get a hold of Mikuni and ask them for a guide?
Rudy
Rudy
cycle-x sells dual mikumi cv for honda 750 contact them they very helpfull.
Well...this prolly doesnt really help as these are for a GS650 but these models use MiC BS32SS CV carbs....
GS 650 GZ/GLZ (82)
idle r/min 1100-+/-100r/min
carb mik bs32ss (4 seprate carbs)
id no 34300
bore size 32 (1.26)
float height 22.4.+/-1.0 (0.88 +/-0.04)
fuel level 5.0+/-0.5 (0.20 +/-0.04)
main jet #110
main air jet 2.0
jet needle 5C45
needle jet Y-7
pilot jet #42.5
throttle valve #135
by pass 0.8, 0.7, 0.8
pilot outlet 0.7
valve seat 2.0
starter jet #45
pilot screw pre-set (1.5 turns back (mixture screw))
pilot air jet #160
throttle cable play 0.5-1.0 (0.02-0.04)
choke cable play 0.5-1.0 (0.02-0.04)
GS 650 GD (83)
id no 34300
bore size 32 (1.26)
main jet #110
main air jet 2.0
jet needle 5C45
needle jet Y-7
pilot jet #42.5
throttle valve #135
pilot outlet 0.7
valve seat 2.0
starter jet #45
pilot air jet #160
GS 650 GLD (83)
id no 34390
bore size 32 (1.26)
main jet #107.5
main air jet 1.2
jet needle 5D59-3rd
needle jet X-2
pilot jet #47.5
throttle valve #135
by pass 0.8, 0.8, 0.8
pilot outlet 1.0
valve seat 2.0
starter jet #32.5
pilot screw pre-set (2.5 turns back (mixture screw))
pilot air jet #160
And This is the BS34SS but on a GS1100
'83 GS1100ED(Canadian model for sure)
Carb Type Mikuni BS34SS
Bore Size 34mm
I.D. No 49360
Idle r/min 1050+100r/min
Fuel Level 5+.5mm
Float Height 22.4+1mm
Main jet #112.5
Main air jet 1.2mm
Jet Needle 5D9-3rd position
Needle jet X2
Pilot Jet #47.5
By pass .8mm
Pilot Outlet 1mm
Valve Seat 2mm
Starter jet #32.5
Pilot Screw 2 1/2
Pilot air screw #160
Throttle cable play .5-1mm
BUTTTTT!!!! Here's a GS450 with '34s on it
US 450 models:
Make: Mikuni
Type: BS34SS
Venturi Size: 34mm (1.34 in)
ID number:
ED: 44400
LD, TXD, LF: 44460
Other models: 44110
Idle Speed:
ED, LD, TXD: 1200 +- 50 RPM
Other Models: 1200 +- 100 RPM
Fuel Level:
ED, LD, TXD, LF: 5.0+- 0.5 mm ( 0.20 +- 0.02 in)
Other Models: 6.5 +- 0.5 mm (0.26 +- 0.02 in)
Float Height:
ED, LD, TXD, LF: 23.0 +- 1.0 mm (0.89 +- 0.04 in)
Other Models: 22.4 +- 1.0 mm (0.88 +- 0.04 in)
Main Jet:
ED: 120
Other Models: 115
Main Air Jet:
ED, LD, TXD, LF: 0.7
Other Models: 0.6
Jet Needle:
ED: 5DX87
LD, TXD, LF: 5CDT60
Other Models: 4C2
Needle Jet:
ED, LD TXD, LF: 0-6 (O-6??)
Other Models: Y-6
Throttle Valve:
LF: 95
Other Models: N/A
Pilot Jet:
ED, LD, TXD, LF: 45
Other Models: 17.5
Bypass:
ED, LD, TXD, LF: 1.0, 0.8, 0.9
Other Models: 0.8
Pilot Outlet:
Other Models: 1.1
Float Valve Seat: 2.0
Starter Jet:
ED, LD, TXD, LF: 32.5
Other Models: 30.0
Pilot Screw Setting:
ED, LD, TXD: Preset (2.0 turns out)
Other models: Preset
Pilot Air Jet:
ED: 135
LD, TXD: 145
LF: N/A
Other Models: 1.6
The Cycle X CB750 Carb kit has Mikuni VM series carbs.
http://cyclexchange.net/Carb%20System%20Comp%20Page.htm
I have yet to find any tuning manuals on the CV style carbs. Most of the tuning manuals are made for the performance oriented crowd. The CV Style carbs arent really though of as performance carbs. Most performance tuners get rid of the CV style carbs in favor of a slide type carb.
DG
DG
Yeah, so I hear. I don't have the budget to get another set of carbs that are in decent shape. I have two Keihin's from the CB450, but they'd need a lot of cleaning to get them good to go. They're the slide type. The ones I have right now from the XS (2 sets) are the CV types and are in really good shape. So I can't justify not using them. I think I've found some information that will help me out. I've also contacted Sudco to see what they have to say. Haven't heard back from them yet.
Rudy
Not really looking to buy carbs, as I have 2 sets already. I know I can get jets from Mikes quite easily, though it may be easier and quicker to get them from a shop around here. Just looking for a tuning guide.
It is trial and error with these carbs, original OEM. Nothing was made for them. The triple guys, just play around with jet sizes and needle settings, depending on which type of air filter and exhaust they have. One step at a time seems to be the way to do it, Doug
Well, made it out to the garage last night. Put a few things together and found a tuning guide for Mikuni CV carbs on the workbench............ um, I guess things really are in the last place you look. I still have no idea where I got it. I know I printed it out and put it there probably WAY back when I got the bike, but can't remember. So hopefully it works out.
Rudy
I dont like CV carbs at all (my opinion) and I usually go to extremes (so I've been told) to get rid of them.
On my XS 650 I went to 34 Mikuni Flatslides and on my GT 750 I went to 38 Flats. The XS 34's are still being worked on, and the GT 38's realy woke up the GT (with chambers).
DG
extreme's!!!!!!!carbs are worth more than both my race lumps....excellent mod!!!!!
Here a pic of the GT carbs before they were installed. The black cable hooks to the oil injection pump.
and I hate points also, so I made a Dyna S eletronic ignition for the GT also.
The difference in perofrmance between the stock GT and the modded GT are night and day.
Thanks!
DG
