Mikuni VM30 Knockoff
adriannarnold
Coast to Coast
Hey guys,
I recently purchased these on ebay. I know they are knockoffs. If I am not mistaken real Mikunis do not have a flange mount, but a spigot mount. Is this correct?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=320567261376&ssPageName=STRK:MEWNX:IT#ht_1753wt_984
I am having a very difficult time finding any sort of flange to mount to the carb. I thought I found some on Amazon, but they ended up being the wrong mounts, they were for the engine side, not the carb.
At this point should I return these and find some real ones, or am I looking at the wrong stuff for mounting these to my bike. I have a cb350
Any comments and advice is appreciated.
Yeah - Mikuni VM don't have that flange cast into them (as far as I know).
So what mount are you looking for? You lost me at 'they were for the engine side, not the carb'. Do these bolt to your engine as-is or not? If not, you likely need to just buy real VM's and the right size mounting boots, but I'd think these are cast to the same dimensions as the rubber mounts would be.
Sorry for the confusion.
No, these do not bolt straight to engine. Their inner diameters are the same, but the bolt widths on the flanges are much smaller.
I was thinking about finding a flange that would mount to the carb, and then use some sort of tubing that would connect both flanges, the one on the engine, and the one I would put on the carb.
Well, one option (depending on how far out the bolt holes are) would be to turn the bolt holes on the carbs into notches by removing the tips of the flange. Then a nut/washer on the mounting stud (or bolt/washer if it's the other way around) might hold the carbs in place solid enough.
Thats a great idea! I will look into it. I just emailed the ebay seller, so depending on how he wants to handle the return I may really consider that route. Thanks a bunch for your advice.
adriannarnold said:
Thanks djelliot,
Yeah I am pretty sure I will be returning them. Have you used those carbs? How is tuning them etc?
Not yet but I've heard good things. They're suppose to be easier to tune then VM's. I have a few other bits that I need then I will be ordering a set for another CL350 I'm working on. If you get to it first let me know what you think. I have used other OKO carbs and can verify that the quality is good. At least of the ones I've come across.
You cant bolt the carbs directly to the motor of a 350. You need the intake length for the fuel to atomize correctly. I cant remember the ideal length, but its listed on here somewhere. I have the same carbs and mounted them using adapters that BradJ whipped up. Basically its a flange that the carb bolts too with a tube extending from it that slips into the original boots the way the original carb does. They'll work fine that way. The reason those carbs have a flange is because theyre for a dirtbike, not a CB.
Okay good to know. I actually just sent them back. I will look into some real mikunis. Are the mounts Mikuni sells the correct length? If not where should I look for said mounts? Thanks
Im not sure which mounts you mean. If you mean the flange to flange type, they arent made for a 350. The bolt holes are narrower I believe. They are made for a crf or similar dirtbike head.
The Mikuni VM30 I am looking at on DCC have a spigot mount. Will this slide directly into the stock rubber flange that mounts to motor where the old carbs connected.
Or, if I do I need to find so other flanges?
I hope thats not too confusing. Thanks for your help
No. You'll need a set of CB360 carb handlers (intake boots). The stock 350 ones are to small.
