Mono-shock conversion wuestion
Bobby4Prezz
Hey all, I'm sure this questions has been asked a thousand times, but I can't seem to find it so I'll post anyway.
I'm wondering on a mono shock conversion what I need to take into consideration. IE
What size shock to use for the frame?
Does the angle of the shock matter?
Anything you can give me would be great, links, builds, conversion kits.
I'm going to be putting a mono shock on my cm400 frame so I can eliminate the rear section of the frame and do a floating seat, let me know what you
Guys got! Thanks! - Bob
Good thing is at least you're asking.
There's some pretty talented brains here that would tell you to use extreme caution when doing a mono shock. There's a lot of engineering that needs to go into it for it to be safe. Go check out the Bryan Fuller thread of the mono shock cb750 if you want to get a sense of how the board feels about safety and poor engineering :)
Sent from my SGH-T989 using Tapatalk
I'd suggest before you start to make sure you have access to pro level welding skills, as these need to be done RIGHT lest you get hurt.
After that, I'd carefully analyze the stock configuration of the donor rear end. How is it run in the original frame. What angles/linkages, etc.
Now understand that it all boils down to simple physics. Forces, levers, spring rates, vectors and such.
This is not necessarily rocket science, but you really need to make sure you think it through thoroughly.
Hopefully others will comment with their own experiences.
And kudos to you for asking at this point in your process. It can be done, and done well if you sweat the details...
Thanks for the thoughts so far guys. Thankfully Im a certifided tig welder, so I'm not worried about that part. But I was
About the engineering part! Keep the feedback
Coming!
I am just now looking into this for a CM400 buildup of my own. I haven't seen any CM400's with a monoshock before so I'm glad it's being discussed here, too. With the right geometry and spring rates, I'm sure it would be find. Gotta run the numbers tho....
