more than 10% throttle bogs her down
maireeka
Active Member
1978 cb125s
I got it running today. Clutch cable is still not hooked up, but I rode it around the block a few times anyways. Any more than 10% throttle bogs it down badly. Not sure what that means. It will rev up high if i give it a little throttle, but rolling onto the throttle just causes it to die out.
would I need to adjust/fix something on the carb, or mess with the points plate/timing?
This is gonna sound stupid... but lets start small. Do you have the choke open? Make sure you're putting the lever the right way. If the choke is closed then you will bog like you described.
- Woody
choke is open. no airbox right now, open header. I replaced the plug, but the points are still old. Replacing them next. Any other ideas? The new plug made it idle a little better and start easier but it still sputters and dies when you give it more than a little throttle.
messed with the screws, made it worse. i'm takin it apart again to check the clip on my needle thingy. i didn't know it mattered how that was set up, and maybe i've got it set wrong.
