Scruffy said:It will work, even light oil dripped in the bar end until it comes out the cable base works fine. Double check the barrels before you install the cables, Motion Pro ships a lot of faulty product. I've had several throttle cables snap at the barrel/ball, have had several clutch cables snap as well. Too much heat and/or too much solder makes the strands brittle. If there is more than a "blush" of solder wicking, the cable is suspect.
