DrJ said:
I disagree. A good clean solder joint encased in shrink tubing is waterproof and will outlast a crimp which is not sealed. A crimp joint is susceptible to corrosion and adds bulk and looks amateurish. I doubt any serious, experienced builder uses solderless crimp joints to wire a bike. Although a crimp joint is good for roadside emergencies when a soldering gun is not available.
I don't think this looks amateurish:
Solder connections corrode too, and are more brittle.
I know from work experience, most professional connections are crimped (crimped properly). If you are comparing a blue barrel crimp like this:
I'd agree it looks amateurish.
No manufacturer uses soldered connections. No electrician uses soldered connections.
A proper crimp is is mechanically strong, and electrically proper.
A solder joint is electrically strong, but mechanically weak. It is too rigid.
A poor crimp is worse then a properly soldered joint. A properly crimped joint is the best though....
You can disagree with me...but try and find soldered connections on any product other then the circuit board connections.
In a high vibration environment, crimp is the gold standard.
