My '75 CB360 Rat
;D WELL, HEEELLLOOOOO DIRTBAG!!!!!
Much better photos of your 360 on here. That tank is Redonkulous. Mean lookin.
You get to play with your jets? I was going to drill my extra set but seemed to have tricked myself
with the safe place I put them during a late night clean up. F###.
Anyway, I have a regulator problem. Volts are getting up over 16+ and popping tail running bulbs.
Have a brand new rectifier in her and I went through all the ground connections but nothing. Need a new regulator.
Looks good. I have K&Ns on there now. I"m going to see how it runs as soon as I get back from vacation. If it's still coughing at steady throttle im going to lift the needles. If that fails im going to bump up the primary a size.
Time to figure out the rearsets. As seen on my chair. Any suggestions? I figure i'll weld a tab in the triangle.
super kool bike what are you doing with the first seat you had pictored if it is something you would sell i may want for my cl350 if not it is kool your bike looks great
Ok so the final piece of the puzzle is almost in place. The rearsets.
I ordered universal tarozzi's from fastfromthepast.com
Linkage is figured out for the shifting. I need to work on riding position etc.
The brake side is going to need some cuttin and welding. I'm going to cut the existing brake lever and weld on a bushing perpendicular and try and line it up correctly.
No more upswept pipes either .... BOOOOOoooo
looking and sounding good! Did you do something different on the rear brake than you planned. What did you have to do?
Dont look at my rear brake. It's not done. It's just there to light a lamp at the moment.
I never use it. I'll fix it next spring.
The bike sounds great. When do we get the HD video of you carving up the twisties?
