napolean barend mirror prob
RUMPLESTILTSKIN
hee heeeeeee....ehhh....cough....ha (evil laugh)
i've got a barend mirror...that won't stay in place...just the mirror/glass part.
i adjust it, and if i pick up some speed the wind pushes it, and then i have a view of the sky!
anyone had this prob?
anyway to fix it?
or just buy a new one...seems like a waste since it looks great still.
thanks
I think they have a nut to tension the plate - trouble is it's behind the glass :o
You might be lucky and be able to tighten it by spinning the glass plate (clockwise), otherwise you could try a drop or 2 of superglue on the ball joint (make sure it's in the right position ;)).
Maybe try the spray adhesive before super glue. That way if you need to break it free later, you can. Just push the mirror as far down as possible, shoot some adhesive into the ball joint, run the mirror around the work the adhesive in, set it in the right position, let it sit overnight.
THANKS A LOT FOR THE HELP....!!
just wondering are these guesses, or you guys have done this before?
i tried to use black silicon before, it did not hold, seems like adhesive is a great idea.
i also tried last night to rotate the mirror like you suggested, it seemed to get tighter. i will have to test it by riding.
i'll let you know.
I've used superglue before - it's a bit more permanent on plastic bodied mirrors than metal ;D
But if you just use a FEW drops it will not be permanent on a metal mirror joint (you can "crack" the glue free if required ;)).
Superglue ain't that super...
i tried the twisting method, to see if it will tighten...
i tried the adhesive spray...
and none worked.
i guess it's super glue time.
it's crazy, cause one mirror works just fine.
