m511y
Less is more
I was syncing my carbs and all was good, but when going on a test ride I noticed my right carb was sputtering whenever I would first turn the throttle. The Left carb was fine. When starting from a stop, the right carb would sputter and then eventually fire just fine. This leaves me to believe it is a pilot issue and that the main jet and needle is fine.
At first I figured it must be a vacuum leak so I sprayed all over the carb and intake boot with starting fluid. No idle surges. Then I thought maybe the pilot screw was clogged so I removed it while giving it just a little gas, and I could hear the pilot sucking in air.
I checked the plugs and they looked lean, so I though maybe there was a fuel line clog. I checked the line and it is flowing just fine. (now I smell like gas :-[)
If I slowly roll on the throttle it acts close to normal, but if I crack the throttle back, the right cylinder dies.
What am I missing??? Figured I would ask before breaking the carb down. I hate opening up my carbs. Jetting them was a pain in the ass.
