have they been cleaned properly????your pissing into the wind if they haven't
..you can't tune or balance plugged carbs,,,,if you plan to ride this,,,you might want it to idle.that is first on your list,(read back) adjusting needle height can be done but requires washers to shim the needles,,,don't waste your time, as for your main jets,,,what exhaust system???? stock air box?? kn filters??velocity stacks etc...that will determine your high speed performance,,,,and that is what usually gets the most attention .......make it idle and go fast ;D,,,,,,,good luck
