Need help with project!
dukemushroom
1977 xs750 with 850 engine. I got it running like a striped ape last week, great power! It is wired for kickstart only(starter was junk anyway). Got all my lighting wired up, thing is looking great now. It sat over the weekend and now she won't go! Can barely get a sputter. Charged up the battery, I know I've got fuel and spark and the compression is good. Only thing I can think of is timing is off somehow? I did adjust the cam chain, could that have thrown it off? Whoever did the engine swap kept the 750's points system (luckily they also kept the mikuni's!). All it wants to do is backfire now, I'm so confused, maybe I shouldve left the chain tension alone haha! Thinking about getting the electronic ignition to help some, any other ideas?
Did you do anything between turning it off after riding it and not being able to get it to run?
Here's a quick timeline:
Got the bike running decent
Cleaned carbs and put in new floats, adjusted points, new plugs and wires and filters
Re-wired for kick only
For 2 weeks it would start right upon the 1st or 2nd kick
Last week, wired up my new headlight and taillight, separate fused circuit from rest of bike
Today, Adjusted cam chain tensioner to help with fine tuning, afterwards it wouldn't start, used service manual for procedure, can't check timing because it won't start and I've misplaced my timing light.
You can set static timing. The manual would explain it.
You say you're getting spark so that's a good start. Check voltage on the battery.
I trickle charged the battery for 2 hours and then tested it...it has 12.6 V and about 180 cranking amps. I did notice that as soon as the key is turned on it loses about 1-1.5V...I don't know if this is normal or if something is pulling extra, the only thing that is really energized when the key is on are the coils, and the reg/rec, there is no starter and the lights have their own on/off switches, I leave them off while starting.
I'm going to try setting static timing later today.
^ +1
This is what happens when you have a couple of weak cells - as soon as the battery is under load, voltage sinks. Guessing you have a water-cell battery; you can check each cell with a hydrometer (after trying to start the bike) or take it in to AutoZone etc. where they should be able to test for you.
My vote is a bad battery as well. under the load of just coils etc it should still be over 12. Can you boost the bike with a good car battery, engine off on the car? It will tell you if it is the battery. Hook up cables try to kick bike over, if it fires right up like it used to, you solved you issue. Get a new battery.
Cheers,
Well, I guess I will try the battery. Haha...It makes sense though, I'm pretty sure the starter killed the thing, it was a new battery too but the starter didn't do anything but pull on it, wouldn't even turn the engine over. Thanks for the help guys, I will try to get a new battery in and see what happens!
Fill it with battery acid, and put it on the trickle charger overnight while you make sure the rest of the bike is ready to roll. Try it again tomorrow. Might not be ruined just yet if it was new.
I left the battery on a 2A trickle charge for about 20 hours, pulled it off and tested it...13.6V! Put it in the bike, crossed my fingers and after a few kicks she fired up, ran crappy for a few minutes (my dumb***) left the fuel on overnight :-[
I'm afraid some fuel did leak down into the crank case, oil started sputtering out of my breather filter and I could smell it, I don't think it's been long enough to ruin anything though, I hope!
Alrighty, well, it starts up every time now! takes a few kicks if it's been over the weekend but she hasn't let me down yet...but have a new problem. I cannot get this thing to idle right and it has some high speed "cutting out". I've played with the mix screws and the idle screw but it either tries to die or revs up past 2k. It's been jetted for the 3-into-1 exhaust and the pod filters.
The high speed problem is on acceleration it bogs down at about 5k, I can sometimes find a seet spot in the throttle that'll get me past that but then it'll bog again, kinda scary when trying to merge onto the highway!
I can't remember all of the jet sizes off the top of my head right now but I think the main is a 145.
I just read the sticky on why not to use EMGO filters, so I took the off, high speed issue pretty much gone, hahaha. So now it's just idle!
You really need to sync the carbs on an 850, they are pretty touchy. Why would you have to rewire the bike, if you're not using the starter? Just asking. Also these bikes have several ground straps, make sure they are all in good condition. I've had a bout a dozen of these bikes, and if you spend a few extra steps on setting them up, they run hard. I had Emgo's on mine, worked fine, but I spent extra time getting them sync'ed. The butterfly shaft seals have a tendency to leak and cause idle issues, cheap fix. Getting good seals in the carb's and getting them synced is the trick to getting these beasts running right. Once set up properly, you'll be hooked on triples. Excellent bikes....
It was actually an easy fix and something I'm pretty embarassed about....I aimed my fuel inlets up (so gas would feed down into them) and it started pulling real hard....only problem now is it's running rich.
