need some help or advice.
bane987
i have a honda cb 360. trying to fix it up and get it started. the start stop switch had broken and i found a retro one for a lot cheaper. problem is i have no clue how to wire it. or if it will even work. the new start/stop switch is very basic its black, white, green, yellow but the old one has way more and no green or yellow. so if this makes any sense to anyone. i could use the help. or i might have to bite the bullet and buy the original style start stop switch. any help would be great. i would love to figure this stuff out and learn how to do it, rather than pay someone. so i know this is the best place to get help
Where did you get the switch? Did it come with a wiring diagram?
What model/year CB350 do you have?
Without this information it's pretty difficult to help... If you don't have this information, you'll need to determine what leads on the switch are connected to the other leads in all the various switch positions. (For instance, in "Run" two wires will show continuity between them. Measure with a multimeter)
-Deek
I see you have no light switch so you have either a late model 1975 or a 1976 model.
The Starter switch, besides starting the the bike, disconnects the headlight so that the starter has a little extra current and enough volts to make a spark. That is 3 wires.
The Kill switch has 2 wires.
You need a schematic, for the late model CB360, not the early. I have one, but not at work...
The older bikes grounded the solenoid to start, but late model provide 12V, so if you use an old schematic you will just burn up wires and switches.
You need either the right pod from a late 75/76 CB360, or one from even a CB600 or 550. I used a CB600 on mine. The start switch was actually 2 switches and 4 wires, but I connected the black power supply wire to the 2 center connectors of the switch and duplicated the single pole, double throw original switch.
I'll send a schematic later, but if you search around, you can find one. Make sure it says Late model on the diagram. The earlier models and CB350 models have different wiring.
cool thanks for the help guys. ill try to find a wire diagram. i know the light switches and horn and all that is on the left handle bar. and the start/stop is on the right. i have a manual for it and it has a wire diagram but its not cb360 specific, so i will look for that. and the model is a cb 360 t and its a 1975. i got the new switch from dime city cycles but it didnt come with any kind of wire diagram. lol so now im kinda like over my head. hahaha new to bikes and electrical is my worst enemy. but i appreciate all the info!
