Need some rear suspension measurement help, CB/CL350
alzcbz
I have a 73 CL350 that I got as part of a package deal with bins full of parts. The PO was in the process of doing a hardtail and had already cut the frame. The rear was suppose to be bolted on the bottom and welded at the upper frame.
I've changed the direction and want to do more of a café bike. Removed the rear end and reinstalled the swingarm.
I plan to use stock length shocks. 18" wheels front and rear with stock CB forks.
If the bike is on the center stand, what is the distance the rear wheel is off the ground(Ground to rim)? Just a rough measurement would be great.
Also need a measurement of upper shock mount to rear tank mount.
CB/CL measurements would be fine.
Please don't flame me for not taking measurements before, because that wasn't an option.
Thanks for your help.
i think the best solution is if someone can give you an accurate measure from swinger bolt center to shock mount centers
then a good one tank mount back to shock mounts you would have the triangle
from there you can play with shock lengths a bit
oh and am very glad to see you are saving a good bike from being a worthless poser hardtail ;)
Thanks for the suggestions. I would be willing to trade the hardtail, titled Cl frame for a stock titled cb/cl. I posted that in my regional section, MI.
I guess I'll just wait til someone posts some measurements.
